No sound afterexecuting Play Sound File.vi from the Examples
I had programs written in LabVIEW 8.0 using the lvsound.dll file.  When I upgraded to LabVIEW 2012 and beyond, I could not get these programs to work any more.  I looked at the http://digital.ni.com link and tried to used the example from the Example menus.  I tried to run this program pointing to a wav file from my directory, but nothing played because it asked for the device ID.  How do I go about getting the device ID and the program to work to play my wav files??
Attached is the Play Sound File example.
(3,352 Views)
This vi work correctly.
Dev ID start from 0. If you have one sound card, use 0.
Or you can use "Sound File to Sound Output.vi" from examples.
(3,335 Views)
I get the error code "4810"  Can you tell me what this means?
The Sound File to Sound Output.vi does work though
Thanks.
(3,325 Views)
see
(3,316 Views)
