No value from case
I have problem.
I wrote a program which generate numbers and then write to file.
If case condition is fullfiled the value need to write. In other case the program need to go to the next loop and do nothing.
What can i change in program to solve it?
Regads
(3,664 Views)
Accepted by topic author piotrek1349
Conditional Tunnels to the rescue!  Right-click on the output tunnel and select Tunnel Mode->Conditional.
(3,655 Views)
A lot of thanks:)
(3,623 Views)
