Noise frequencies elimination
You can calculate power from power spectrum, see below.
The power of the signal in a given frequency band can be calculated by integrating over positive and negative frequencies,
P=\int_{F_1}^{F_2}\,S(f)\,d f + \int_{-F_2}^{-F_1}\,S(f)\,df.
http://en.wikipedia.org/wiki/Spectral_density
Kudos and Accepted as Solution are welcome!
Message 11 of 11
(274 Views)
