Noise pickup in Labview but not in MAX?
I'm having some problems with picking up what i assume are noise peaks while running labview VI's. These peaks are not present when i look at MAX... only through labview. For example, i get periodic peaks of +- 2 degrees in a simple TC VI. Same thing occurs with other VI's i have created. Could i be missing something in my programming, or is it simply a physical connection somewhere?
Mike
(2,841 Views)
Mike,
Are you using the same data acquisition rate? It is hard to see how it could be a physical connection if you are sure you are using the same analog input channel. Is the input configuration the same (Differential, RSE, or NRSE)?
Allen
(2,838 Views)
Also check if you are setting similiar high and low limits for that particular channel, in both MAX and your VI
(2,828 Views)
