Noise spikes in Labview
I am getting a lot of what i would assume are noise spikes in Labview. These spikes don't show up in MAX... only when running a VI. Could their be something in the VI diagram i'm missing, or would it strictly be a physical connection? Any help would be appreciated. Thanks
-Mike
(2,728 Views)
Mike,
You did not give us much to go on. Please list your hardware and software, including the software versions. Describe what kinds of measurements you are making and under what conditions you see the problem and when you do not. Posting code with typical data saved as defaults ( for those of us who do not have the same hardware you do) is very helpful.
Lynn
(2,722 Views)
