I have modified my VI to filter the Gaussian noise I'm generating. I use a 5th order, low-pass Butterworth filter and I set my cut-off frequency to 700Hz. Like you mentioned I do observe some attenuation around 500Hz, but I'm not sure whether this affects my results. I have attached a pic of my results and my VI. As you can see from my Bode plots, the noise has been significantly reduced when compared to what I had before, however I still do obtain some noise in the results and I haven't been able to reduce it. I'd like some help on the following questions about my results
1. I'm not sure what the Sampling Rate of the filter does to my results. When it's at 15000Hz, I can see that the attenuation starts at around 500Hz. However, if I set the sampling rate to 5000Hz the attenuation starts at 2500Hz (same cut-off frequency of 700Hz was entered in both cases). However, even though these two sampling rates seems to affect the frequency at which singal attenuation occurs, it does not affect my results too much.
2. Like you've mentioned, I'm still not sure what cut-off frequency I should enter for my filter. I tried cut-off frequencies from 500Hz to 1200Hz. Again this didn't affect the results much (there were only small differences in the Bode plots).
3. I tried changing the signal amplitude, the data acquisition time, order of the filter (from 5 to 4) without observing any improvements in the results.
4. I don't understand why the results are noisier for frequencies less than 50Hz and for frequencies greater than 450Hz. This was observed for all the tests I did. The only reason I can think of is that this might be a characteristic of the system.
5. You mentioned in your previous post that my fs on the AO clock is set to default. However, I have actually set it to 15000Hz. Am I missing something here?
I have changed various parameters of my VI (amplitude, acquistion time, order of filter, sampling rate of filter, type of noise (gaussian and uniform white noise)) but haven't been able to observe any significnat improvements in the results. Would be grateful if you could spot something I'm doing wrong or any further suggestions.
Cheers.
Message Edited by imperial-aero on
04-13-2008 10:43 AM
