Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Non-Latching switch
Non-Latching switch
Tom
Member
11-06-2003
11:06 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is there a switch which does not latch ie the output goes from FALSE
(default) then TRUE and then back to FALSE with some pre-programmable
delay in between? Rather than the usual latching switches.
Tom
0
Kudos
Message
1
of 2
(2,809 Views)
Reply
Re: Non-Latching switch
paul_s
Member
11-07-2003
12:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Here is a solution using property node. (run continuous or set true before running)
latch_boolean.vi 20 KB
0
Kudos
Message
2
of 2
(2,809 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
