Non National Instruments DAQ Boards
How do you configure (add) a non-National Instruments DAQ board, which is compatable with labview (IOtech DAQBoard 2000 - PCI), in the "Measurment and Automation Explorer" for LabVIEW?  It currently does not display that the device is seen under the "Devices and Interfaces" section.  All necessary software for the board has already been installed.  Any help would be greatly appreciated.
(2,840 Views)
MAX is a program from NI, to configure and test NI boards, it is not meant to use with boards from another manufacturers.
You should use tools that should be available from your board manufacturer.
Paulo.
(2,836 Views)
