Non-blocking Open SubVI
Thank you to all who responded...
Message 11 of 13
(1,341 Views)
I have been using the Invoke-Run VI to launch daemon type subvi's and I am now trying to launch a dialog type vi.  The subvi is basically a intrument control panel that changes settings.  I want the main VI to still run and respond.  Everything works except for when I close the subvi called via VI Server either by the X or file->close the front panel stays visible.  Is there a way for the VI to know to close it's front panel?  The VI properties setting do not work.
Message 12 of 13
(1,117 Views)
You can place logic in the VI that will close itself once its done executing...just create an invoke node with 'FP.Close'
Message 13 of 13
(1,101 Views)
