Non-linear error and gain error
Hello, I need to calculate the gain and non-linearity error starting from the parameters of the regression line calculated following the measurement of a voltage using an oscilloscope and multimeter.
Is there a block or set of them in labview that allows me to calculate?
I hope I get the idea of what I want to do.
(1,671 Views)
Check out "Regression Solver.vi". You can find it at:
C:\Program Files (x86)\National Instruments\LabVIEW 2018\examples\Mathematics\Fitting\Regression Solver.vi
(Adjust path for your LabVIEW version.)
Founding (and only) member of AUITA - the Anti UI Thread Association.
(1,654 Views)
