Non time dependent limit testing
Have you checked out the Limit Testing and Limit Specifications vi's in the Waveform Monitoring Pallet. There are also a couple of examples you can get to from the Labview Help - Limit Testing Measurement.vi and Limit Testing for Uneavenly Sampled Data Measurement.vi
Ian
Message 11 of 13
(638 Views)
Looks like you will have to convert your XY graph into waveform or array data to do the limit testing. Or you can take the data with negative x values and flip it to the positive side. Do the limit testing, then flip the results back to the negative side.
Message 12 of 13
(627 Views)
Find this llb file for some examples on resampling into waveforms.
C:\Program Files\National Instruments\LabVIEW 7.0\vi.lib\measure\maresamp.llb\Resample Array of Pairs (single shot).vi
Message 13 of 13
(624 Views)
