Normalize End of Line in Malleable VI
I need to normalize the end of line character in a string. I am using a malleable VI that dehydrates a cluster to JSON and another that rehydrates JSON back to a cluster. Malleable VIs are inlined. How does that affect something like Normalize End of Line.VI that determines how to behave based on the operating system that it is running on?
(2,545 Views)
I just executed a VI that calls a malleable VI that converts JSON to a cluster. I copied the JSON file from a Windows computer to a cRIO 9053. The malleable VI was able to read the file, but there was no rehydration, just like when there was no Normalize End of Line.VI call.
Can I roll my own Normalize End of Line.VI using a conditional disable structure and call that from a malleable VI?
(2,537 Views)
No code = No help
(2,478 Views)
Can Normalize End of Line.VI be called productively from within a malleable VI?
(2,470 Views)
Put another way, what does Normalize End of Line.VI do when it is called from within a malleable VI?
(2,468 Views)
