Not able to edit VI Icon developed by NI (TestStand User Interface)
I'm able to change the Icon on the VI that you attached.
I also did try to locate that VI on my PC, but my TestStand 2014 SP1 32-bit does not have that vi in the examples.
Message 11 of 12
(765 Views)
Thanks for the reply, i have tested the same in another system and it works fine..Smiley Happy
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 12 of 12
(745 Views)
