Not able to get the readings for the VI which used to be perfect.
Goodevening Respected Members.
 I am really in need of your help even though it is small. I am not able to get the readings when I run this VI , it used to work so fine all this while . Today , when I ran the VI , I wasn't able to get the readings of the thermocouple. It is very strange to have come across such a situation because the VI used to be perfect all this while.
I am using NI Crio 904x.
All I changed is the MOD of the Crio. Please help me. I will attach the VI , please check if you all are getting the readings when u run the VI.
Would be great if I could get a positive reply from someone.
Thank you all. Means a lot.
(2,337 Views)
(2,333 Views)
What is the "MOD" and why don't you change it back to what it was? Who wrote the VI?
(2,323 Views)
Vi was done with the help of this forum , and it was working fine till today.  There are 7 Module slots in the compact RIO.
 Could you check if the VI is working ?
(2,320 Views)
Do you have a link to the forum discussion where you "got help"? That would be the right place to ask. We don't have your hardware to test.
(2,316 Views)
What goes wrong now?
Do you get an error anywhere? You might be able to see this if you run it with the PC connected (so interactively, rather than as a RT-exe application).
Make sure to check each of the possible error sources - your top set of errors can be probed but don't display otherwise.
GCentral
(2,252 Views)
