Not able to open any project file in lv 8.0.1
I'm not sure that what happened.
Now the situation is that project files wont open while simple vi and other files open without any problem.
Please help me.
Message Edited by PIPL on 05-02-2007 12:49 PM
Using LabVIEW 8.0, 8.0.1, 8.2
(2,990 Views)
Hi PIPL,
What exactly happens when you attempt to open a project file? Does LabVIEW simply hang, or is there an error message, or what? Are you able to create new projects?
-Sam F, DAQ Marketing Manager
(2,979 Views)
It simply hangs...
(2,972 Views)
Hi PIPL,
Are you able to open a new project?
It might be worth repairing LabVIEW. To do this (assuming you are on Windows), go to the Control Panel, then Add or Remove Programs, and select National Instruments Software. Click on change, and then find LabVIEW 8 and select repair.
(2,962 Views)
Hi all,
Thanks for your support.
The problem is rectified.
(2,938 Views)
