Not able to open excel sheet
Hi.
If i read the excel sheet immedialty after disposing it,  throghs an error saying can't open the file.
Please see the attached vi. Call this twice for same file without any delay throughs an error.  I am giving the correct parameter.
I added 200ms dealy to avaoid the problem.
NOTE: this problem is seen in high speed systems.
Please let me know wheather my ci is wrong.
Thank you,
Ranjith
Message 1 of 8
(4,248 Views)
Your VI is not attached.
Message 2 of 8
(4,247 Views)
hoops... sorry for that..
Message 3 of 8
(4,239 Views)
Hi Ranjith,
do you use a template? I can´t see the described behavior, also not if i delete the 200ms wait.
Mike
Message Edited by MikeS81 on 07-16-2008 07:58 AM
Message 4 of 8
(4,235 Views)
No. Its not template. Even In my PC this problem is not seen. This problem seen in other PC's which are high speed .
Message 5 of 8
(4,222 Views)
Hi Ranjith,
why do you need to call it so often? Can you explain please? Maybe its possible to change somthing, to get what you need.
Mike
Message 6 of 8
(4,209 Views)
Yes, i need to read 3 sheets from xls file.
Message 7 of 8
(4,207 Views)
Hi Ranjith,
but in your example you create everytime a new report! You can open your file ones and read then three sheets. For more information you can also see the Excel Board.
Mike
Message Edited by MikeS81 on 07-16-2008 12:26 PM
Message 8 of 8
(4,205 Views)
