Not being able to change the value of cluster elements programmatically
Hi everyone,
I hope someone can help me. I want to change the value of the cluster controls programmatically. Normally I go over Property Node -> Value -> Change To Write -> Create Constant, where I can set my new values (FIG 1).
But there is a case, where I cannot do it. The Value gets a violet colour and there are no constants shown as normally. Could you please help we with that? An image is attached.
Thank you,
Jani
(2,058 Views)
Give the cluster elements unique names.  Then you can get a property value node to "Cluster.ElementName"
(2,054 Views)
Attach your code, not a picture.
(1,994 Views)
The violet color means that it's a variant. Without seeing the code (just a simple VI  containing the two cluster is all we need!) we cannot tell you why that is. There could be many reasons.
(1,992 Views)
 The picture tells a lot.  Cluster 2 is typedefed. We can see the black glyph in the constant top left and no Coercion dot.  So, we want the ctl file too to get the whole story.
Axis control Cluster is an empty cluster (archsesteurung is German) we can tell from the black type bar in the node.  Oddly,  the created constant of an empty cluster and any  property value nodes are of type variant not type empty cluster. (Actually, that does make a weird kind of sense since VOID var is the only sane value)
Likely, the new ctl has unapplied changes or hasn't been edited to add the ( assumed Xpos, Xpos and boolean option elements)
(1,969 Views)
The OP did not have a problem with cluster 2, so we don't really care about that. The problem is with the one on the right and most likely you are right with the empty cluster theory. The question is why is it empty? That alone would break the code, of course. I was assuming that the code was otherwise runnable.
Unfortunately I was probably wrong with my assumptions regarding the LabVIEW skills of the OP. 🙂
(1,956 Views)
With that Black type bar in the property node, the code has a broken run arrow without a doubt.
(1,949 Views)
