07-16-2013 06:55 PM
We've been using the hokuyo URG series lidar in the robotics simulator but we can't get more than 29 data points out of it. We get hundreds when running the sensor in real life. Is there a way to increase the number of data points read in the simulator? It is too low to be useful at the moment.
thanks.
(Using Labview Robotics 2012)
07-17-2013 10:04 AM
07-19-2013 07:06 PM
I've tried the goalkeeper example code and that also gets out 29 data points. Changing the loop rate does not seem to affect this. Any other ideas to try?
thanks.
07-20-2013 08:08 PM
I believe the default scan angle for the simulated Hokuyo lidar sensor is 5 degrees. With max and min angles of +-70 degrees, this explains why you're seeing 29 data points. You can change these settings in the Simulator wizard. Right-click the simulation target in the project, and select Properties. In the wizard, select the Hokuyo sensor in the tree, and scroll down to change the "Max Angle", "Min Angle", and/or "Scan Angle" parameters.
07-20-2013 08:18 PM
Awesome, that works 🙂 Thanks.
