.Not executable subVI
Using LabView / fieldpoint with FP-1601, FP-TC-120 and FP-DO-410 I can use MAX to test the inputs and outputs, however when setting up any fieldpoint application in the labview window I get an error, of which states 'the subVI is not executable'.  I've checked and re checked but cannot seem to bypass this happenning.  There must be something small I'm not getting set up right.  Any ideas?  Thanks in advance.
Steve
Message 1 of 1
(2,577 Views)
