Not getting real time FFT for a signal.
I wanted to obtain the real time fft for a pulse signal and tried using the "fft by pt" sub vi with a window size of 100. I have used myrio for acquiring the signal and sampled it at 200hz. The fft shows a peak at 0 and goes to 0 level at 1. I am not able to figure out. Can anyone please help me out?
(1,448 Views)
Going only by your limited information (you have not shown a vi, sample data or described the pulse width or repetition rate) I would have to conclude that the record indicates a large component of between 0hz and 2hz.  This does not surprise me in the least! It's a PULSE!
(1,422 Views)
  • How wide is the pulse (in # points compared to the 100 point history size).
  • is it a square DC pulse or a pulsed high frequency signal?
  • An FFT output is complex. Are you looking at the correct phase (or magnitude)?
  • if your ptbypt size is 100 points, you'll only seem something for less that half a second at 200Hz).
As a first step, generate a static array containing your expected pulse and do a plain FFT. Work if out until you see what you expect to see. Then go back to the ptbypt, but use a simulated signal. Only once everything is worked out, go back to the real signal.
(1,416 Views)
Will try it out and get back to you if there is any doubt. Thanks a lot for the inputs.
(1,391 Views)
Thanks a lot for the inputs. Will definitely try to include more info next time.
(1,390 Views)
