Not reading the right data value
So I am reading data from a txt file that I created,in particular I am trying to pull out the first column which is the time data.  When I read it using the "Read from spreadsheet file.vi" I am getting unexpected values. For example when the first value in the file is 1491.044016 it displays 1491.044067, it does this for every value? I thought it may have been a formating issue but I set the vi %.9f on the formating field I'm not sure why it is handling the values this way? Any insights?
thanks,
Chris
(2,843 Views)
Are you using LabVIEW 7.1 or older? In this case, "read from spreadsheet file" uses only SGL precision, which is not sufficient for your desired resolution.
See also: http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=315189#M315189
Solution: Read the file as a plain string and then use "spreadsheet string to array" with DBL as type.
... or upgrade to LabVIEW 8.0 or higher. 🙂
(2,835 Views)
