Not sure how to implement the 'Create File with Incrementing Suffix' VI to save images
@navman74 wrote:
No I didn't what is supposed to go in the file path box?
Browse for the same path that you would if you were using your original code with the filepath dialog. Make sure you are using the Path Only VI I included above.
Bob, your link isn't set up properly.
Cheers
Message 11 of 12
(1,274 Views)
Oops, my bad.  Search for "How to save acquired Images", June 21, 2016.  My reply with a Snippet is on Page 2.
Bob Schor
Message 12 of 12
(1,257 Views)
