NotEnoughMemory
Hi, all -- brand newbie here..
I've LV8 and IMAQ. I dl'd from NI
'Imaq_continuous_acquire_and_snap_lv71.vi' and it will load, apparently
properly.
When I click 'run' I get the message 'there was not enough memory to
compile this vi' and below 'you must make more memory available for
labview to generate the code for this vi.'
Well the system [XP and maxRAM] is as big as possible, and I can find no
way to 'make more memory available..'
Is there an issue with using 7.1 code in lv8?
Any and all help is most welcome.
chris
(2,911 Views)
Chris,
Thanks for your post.  There are no known issues with LV 7.1 and 8.0 using the same code.  LabVIEW has always been designed with backward compatibility to allow you to open any previous VI in the newest version of LabVIEW.
Does the VI work fine in LV 7.1?  It is possible that if you have multiple applications open at the same time that there may not be enough memory available.  Try looking at the Task Manager in Windows to see what the memory status is on your PC.  Also, try opening LV 8.0 by itself and open another example (may DAQ, etc) to see if there are any other issues there (it may be that there is an issue with your LV installation).
Scott Savage
Applications Engineering
(2,897 Views)
