Notepad++ ActiveX Control
Dear NI Community,
I've got one small question.
I'd like to play a bit with Notepad++ ActiveX, and I'm wondering, whether it is possible to use it as ActiveX control inside the VI. I've installed and registered Notepad++ ActiveX plugin, but I can not find instance of this class via ActiveX Container.
Did anyone worked with it, please? Maybe, someone know solution, how to embed it into VI front panel?
Thanks a lot in advance!
Message 1 of 15
(11,228 Views)
Does Notepad++ actually have an ActiveX Control, or does it just have an ActiveX programming interface? If it's just the latter, then there's nothing to put in an ActiveX container.
(blog)
Message 2 of 15
(11,224 Views)
Accepted by topic author kosist90
I presume it's only an ActivX Interface?
- Notepad++ 6.8.8
- ActivX plugin 1.1.7.3
- LabView 2015
after installation open a new vi, and press ctrl+shift+b to open the class browser
the default is VI server
you have to change this to ActivX > SELECT LIBRARY
I suppose the Notepadd++ library is "NppActiveXPluginTypLib Version 1.0"
Message 3 of 15
(11,192 Views)
Thanks to everyone for the answer!
Just small update - as it is found, in LabVIEW anyway neither container for front panel, nor property/invoke nodes on the block diagram are not available for this ActiveX Notepad++ plugin...
Message 4 of 15
(11,095 Views)
Not sure what your goal is but you can use the Rich Text Box ActiveX control to embed basically a notepad environment on the front panel of LabVIEW.
http://digital.ni.com/public.nsf/allkb/7CFE9838693EFF53862575ED005770FA
Message 5 of 15
(11,063 Views)
okay, I just learned, in notepad++  you have to navigate to activex plugin>setting>register
then the NppActiveXPluginTypLib Version 1.0 will show up in:
Looks like this "register" does run an .exe which can be found in "C:\Program Files (x86)\Notepad++\plugins\ActiveX\RegisterActiveX.exe"
Eventhough, if a invoke or property node is dropped on the blockdiagram, you can't run your vi 😞
So I looked up a tutorial from "activex plugin>help..>How to use this ActiveX Plugin?"
Type this lines ov visual basic code in  an open notepade, save as .vbs, and then doub-click the file
Option Explicit
Dim NppApplication
Set NppApplication = CreateObject("NotepadPlusPlus.Application")
Call NppApplication.activeEditor.newFile()
Call NppApplication.activeEditor.write("This text has been written by the example script!")
This  (kind of) works! Notepad++ opens a new file with the content "This text ..."
Trying to build this with nodes in Labview, seems straight forward.
Does someone know how to do:
Message 6 of 15
(11,044 Views)
hI,
Will it posibble to convert the Ascii  to hex using notepad ++(Because im working with chineese cheracters.)
Vivek
Message 7 of 15
(9,601 Views)
Hi vivek,
why do you want to use Npp for this conversion? Why not use LabVIEW?
Message 8 of 15
(9,597 Views)
Hello GerdW,
Thanks For Your ReplySmiley Happy
My need is im working with a language verification with Google tesseract (.net assembly).
Tessaract will give the output OCR in language other than english and it will be stored in a text file.
in labview is this possible to compare 𥱰=𥱰.
So i need to convert 𥱰 to its eqvalent unicode.
please advise if any ways to do this.
Notepad++ will have a plugin to convert Ascii---> Hex.
VIvek G.
Message 9 of 15
(9,593 Views)
Hi vivek,
to convert "ASCII" to "hex" in LabVIEW all you need is the StringToU8Array function…
Message 10 of 15
(9,586 Views)
