Notification of scale range change
Hello Developers!
Does anybody know if it is possible to determine programatically if a Waveform Graph Scale has been changed with the zoom tool or manually modifying the numbers in the scale legend? I thought the Scale range change event notifies the difference, but i cannot get it.
Thanks in advanced.
Regards.
(3,151 Views)
@ibvp_ss wrote:
Hello Developers!
Thanks in advanced.
Regards.
you could store the scale value on a shift register and compare the before and now values to not equal to bool out a change
(3,146 Views)
why do you need to know how the scale was changed?
Only idea how to do until now: Monitor the range - if only one element changed it was *most likely* done by entering a new min or max.
Regards
Florian
(3,135 Views)
Thanks both for the answers. I will check if it works later.
I need this differentiation because I am creating an Osciloscope. If the change is made manually we need to create the new scale and the new grids starting in this new point mantaining the time/division value, but if we zoom in, the programm should recalculate even the val per division.
Regards.
(3,109 Views)
@ibvp_ss wrote:
[...] the Scale range change event notifies the difference, but i cannot get it
This works for me.  What isn't working for you?
Jim
(3,100 Views)
Hello Jim,
Yes, that works. The thing is that I cannot get the info about how was the scale modified. I need to know if the user has changed the scale manually writing down a number in the scale legend or if it has been done with the zoom tool...
(3,093 Views)
I don't know how Rube-ish this is, but it works.  What it does is takes advantage of the fact that the zoom tool will (probably) change both axes, while typing will only change one.
Jim
(3,084 Views)
