Notifier - for loop
I am making a parallel program so I need to use a notifier to tell one of this processes that one has an event.
To make it easier I build a more simple program.
I have a FOR loop that iterates for 1000 times. I need that each iteration is executed once a Ready (OK) button is pressed, and if it's not needs to wait until is pressed. Also, I need to have a STOP button that if pressed at anytime, stop the program.
I built a notifier WHILE structure to make the waiting until is Ready button is pressed, and an EVENT structure to poll the READY and STOP buttons.
can you tell me what I am doing wrong?
Message 1 of 60
(7,401 Views)
Hi Stavros,
A lot is wrong in your image:
- You constantly request for a notifier and delete it in your inner loop.
- You have a wait function in your FOR loop, when you want to wait for a notifier…
- You have a long running FOR loop in your event case, which is a no-go!
- Why not just read the notifier with a timeout? No need to use a while loop at all!
- You haven't used the automatic block diagram cleanup function…
Message 2 of 60
(7,376 Views)
Hi Gerd,
Thanks for answering.
here some clarifications:
I delete the notifier constantly because I need to use it only once, maybe I am missunderstanding how it is used.
The wait function was only to allow me to see the changing numbers.
Why you mean by no-go? I only added the "conditional terminal" in case I wanted to stop it.
- Why not just read the notifiers with a timeout? No need to use a while loop at all!
timeout? do you mean a stop timed structure? I used a while because I wanted to be waiting and don't run another FOR iteration until the Ready button is pressed again.
yes, You are right in this. I just wanted to be focus on the functionality first.
can you give me some tips how can I improve this or make it simpler? maybe changing or replacing some structures......
Message 3 of 60
(7,369 Views)
Hi Stavros,
No, no additional structure.
Just the timeout input of the ReadNotifier function! (Read the help for this function!)
Message 4 of 60
(7,358 Views)
OK, so you meant about the timeout variable in "Wait on notification", but by default is -1. I can't use a certain time, because I need to wait undefinetily until notification is received.
why my stop button is not working?
Message 5 of 60
(7,338 Views)
Hi Stavros,
Because you wait for ever on a notification…
Message 6 of 60
(7,323 Views)
Hi Stavros,
waiting indefinitely without the possibility to shut down is rarely a good idea. However I think that you're thinking a bit complicated for this: If you just want to wait for the button to be pushed, a simple event structure within the for loop would be your best bet. That event could also handle the stop case.
Antoher Question I'm wondering about is this: you want a program that has the user clock 1000 times befor it's finished? Why? How would you feel if Microsoft gave you a program like that?
Remember Cunningham's Law
Message 7 of 60
(7,312 Views)
Hello Peter,
As I told before, this is a simplifier case of a bigger program.
In my real program I do not count until 1000, but I have an array file which is read by the for loop, line by line.
I need to get those parameters, to execute another loop process, for that reason I need the events. Which in this case, are simplified by buttons, but actually are triggered signals.
You are rigth that I am complicating me a lot.
The case you mentioned it's fair enough, but before this process I am running another task, which I wanted to be holded until a Begin button is pressed.
So to sum up I should required a begin button, stop button, and "variable?"(trigger signal) as events to manipulate this for loop.
Managing this trigger signals, I thought using Notifiers was the best option, maybe the buttons can be used in a single event structure?
Message 8 of 60
(7,289 Views)
Maybe it's clearer to see it in an image.
This file is wrong also, but helped me to figure it out a better idea.......
The FOR loop goes until the end of the inserted file.(EOF)
Message 9 of 60
(7,274 Views)
Hi Stavros,
A VI would be so much better…
But still:
It seems your event structure is called before the loop. You try to react on events in your loop, but the event structure can only process the events once the loop has finished (THINK DATAFLOW!). A classical deadlock loop!
- Put your UI event processing in a parallel running loop.
- Use shift registers for references.
- As told you before: IndexArray can be resized! It does not need constant inputs if used correctly!
- Use the cleanup tool!
- Get the notifier reference once before the loop, close it once after the loop!
- Don't use a while loop in a FOR loop in this application, it's not needed here!
Message 10 of 60
(7,253 Views)
