NuDAQ acquisition using DAQ 2204 - Error 10409??
Hi everybody,
I am trying to set a triggered (using a analog trigger) acquisition from 4 DAQ 2204 cards, but i'm facing some problems:
- I wrote a simple VI that acquires the analog signals from the 1st card using the NuDAQ sub-VIs provided with the card, triggered by a edge trigger on the 1st channel, and plot them on a waveform chart. An error comes out, but everything seems to be set correctly and don't have a clue wht is causing it:
Error 10409 occurred at PLV VI CONFIG
Possible reason(s):
NI-DAQ LV: The specified group is in use.
Does anybody know what could be the cause of this??
 - A second issue concerns the triggering of the acquisition. I would like the acquisition to start simultaneously for all 4 cards, triggered by channel 1 on card 1. However i don't seem to be able to implement that. any suggestion??
Thanks for your help.
Daniele
(2,961 Views)
Hi Babidi
This error appears because at some point in your application you are trying to use a resource that is being used in another place. In this link you will find the solution.
Why Do I Get a 10409 Error (Specified Group in Use) Error When Using NI 6533 and 6534
http://digital.ni.com/public.nsf/allkb/9A06091EA3D97BF186256F350066DA79?OpenDocument
Regards
Jaime Peña
National Instruments Mexico
Ingeniería de Aplicaciones
www.ni.com/soporte
(2,956 Views)
Thanks Jaime. I'll try that as soon as possible.
Have you got any suggestion on how to set a triggered acquisition from 4 different DAQ cards, using as trigger the 1st channel on card1 for all of the 4 cards?? I can't think of a way to do that!!
Daniele
(2,948 Views)
Jaime, I don't have anything like a "Reset VI" to use with the NuDAQ series VI to communicate with my DAQ cards. However i noticed that the Error 10409 doesn't appear the first time i run the VI after closing and re-starting Labview, while if i try to run it a second time the error appears. WHat could be the cause of this??
(2,939 Views)
