Num Ctrl, Increment 10 Coerce to nearest
Hi
I want to use Num Ctrl and set the Num Ctrl to increase (or decrease) 10 started from 0, each time I click up (or down) arrow .
In the attached Num Ctrl, I set Increment to 10 and Coerce to nearest in the Data Entry. But when I click up arrow, the number will increase from 2 to 12. When I click down arrow, the number will decrease from 2 to -8. I want the number increases to 10 from 0 when I click up arrow, or -10 when I click down arrow. I tried Coerce up or Coerce down, the result is the same. It is always from 2.
Any help will be appreciated. I am using Labview 2012 with f1 patch installed.
Steve
Message 1 of 8
(3,304 Views)
Accepted by topic author Shijie
Steve,
this is expected behavior.
You tell LabVIEW to increment by 10 from the minimum the control can hold. The minimum is set to -32768 by default (I16). Since this is no integer multiple from 10 (leaving .8, which is no integer), you will result in a "quotient&remainder" function. The '2' is the remainder which offsets your values.
When you change the minimum (and maximum i recommend) to limit and coerce to a multiple of 10, it will work as you desire.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(3,297 Views)
Steve,
The Increment only sets the size of the change; it does not constrain the values of the control itself.
Look at the sneaky way I modified your VI to use a partially hidden control with increment = 1 and an indicator in front of the display portion of the control showing 10*control.
Lynn
Message 3 of 8
(3,293 Views)
Norbert,
You suggestion still fails if someone types a value not evenly divisible by 10 into the control and then increments.
Lynn
Message 4 of 8
(3,291 Views)
Lynn,
you did not configure max/min and increment to coerce 😄
Norbert
Norbert
Expert: Geometry
Message 5 of 8
(3,289 Views)
Norbert,
I did not.  Thank you.
Lynn
Message 6 of 8
(3,287 Views)
Is this a place where the properties dialog box/editor could use an upgrade? In most cases when changing the limits, it seems that coerce should be the default. Why would you set a limit and then allow the program to ignore it?
Lynn
Message 7 of 8
(3,280 Views)
Thank you very much. You have solved my problem.
Steve
Message 8 of 8
(3,263 Views)
