NumText.FGColor
I am having a problem programmatically setting the NumText.FGColor attribute in LV7.1.  I can set the attribute, and then read the value, and it appears set properly, however, the front panel indicator does not change color.  Also, I can change the FG Color of the front panel indicator using the "paint brush", then read back that value, however, I still cannot modify it while the program is running.  I have tried this on various machines, but it does not work on any of them. So I don't think it is a machine issue. Please see attached example.
-Brant
(3,568 Views)
You want to use Properties>Numeric Text>Text Colors>BG Color.
(3,558 Views)
Thanks, that is working. So, do you know what the Properties>Numeric Text>Colors>FG Color used for?
(3,537 Views)
You can right click on the property node and select Help for the particular property you have chosen.  However, I don't know what the foreground of a numeric control or indicator is.  All I know is that there is a text color and a background color.  I tried changing the foreground color to white, black, and some other color, and saw no visible difference.  Perhaps the foreground color property is meant for other items.
- tbob
Inventor of the WORM Global
(3,528 Views)
It's the foreground color of the decoration. Right clicking on a property and selecting Help for ... will provide this type of information. Using one of the classis controls, you can actually see part of the frame change color. I don't see anything with the 3D type controls.
(3,526 Views)
