Number Array VI wont work backwards!
@Pazmush wrote:
Anyone got any more Ideas
Nothing has really worked yet
As suggested, use the Ramp Pattern VI. It's not that hard.
Message 11 of 22
(2,651 Views)
I'm afraid it isn't working how I would like.... for example, if I choose to go between 20 and -9, it will start from -9 and go to 19, where as my instrument will go from 20 to -8...... can someone explain how I can make my untitled a recursive VI
Message 12 of 22
(2,650 Views)
I can't use ramp pattern, it involves needing to know a sample size and if I use one odd number and one even it won't match my instrument... Sorry
Message 13 of 22
(2,647 Views)
You're not even trying. It's called basic arithmetic.
Message 14 of 22
(2,632 Views)
No.... That doesn't work for my purposes, for example put in -10 to 9 and see what you get out what I want is -10. -8, -6, -4, -2, 0, 2, 4, 6, 8
Get it?
Message 15 of 22
(2,619 Views)
with an interval of 2 that is
Message 16 of 22
(2,618 Views)
Any way.... here is my solution, I hope it helps someone.... please advise me if there is a simpler way around this problem...
Message 17 of 22
(2,601 Views)
1) Did you try exchange the start end so that the start is always smaller than the end AND
2) Pass the final results through a revers 1d array?
Ben
Message 18 of 22
(2,599 Views)
LV10 has a new Ramp Pattern VI, until then, here is a range checked recursive version for entertainment purposes.  If it works for you, great, I would probably still use a loop.
Message 19 of 22
(2,597 Views)
Darrin's is better than mine.... isn't it?????
Message 20 of 22
(2,594 Views)
