Number of 7811R in a 1045 chassis
I plan to have seven PXI-7811R in a PXI-1045 chassis.  Since 7811R will all be used for digital data, the PXI bandwidth is not a problem for data transfer to Host VI.  We just wonder if we could have any problem having up to seven 7811R in a that chassis with any controller.
Patrick.
(2,351 Views)
Hi Patrick,
You should be fine using your seven PXI-7811Rs with the PXI-1045 chassis. There are no known issue with it.
Prashanth
(2,340 Views)
