02-11-2010 06:58 AM
I have a slider control with a display format of %.1f which works nicely for the scale. On the Appearance tab I have checked Show digital displays. This display seems to have no formatting control. I tried adjusting the size but it does not adjust neatly, either too many digits or partial digits displayed. Can it not be controlled except by creating my own indicator?
Also I would like to know the difference between Numeric and Digital Display on the Display format tab.
thanx,
jvh
Solved! Go to Solution.
02-11-2010 07:02 AM - edited 02-11-2010 07:08 AM
Go to the slider Properties -> Display Format. And where it says "Numeric" choose Digital Display. Then you can format it.
thanx,
jvh
It seems that you know the answer yourself.
"Numeric" formats the scale's legend numbers. "Digital display" formats the digital display.
02-11-2010 10:35 AM
Mega Duhs on me! I kept looking at that and thinking it was 2 different display formats, not 2 different objects, though I admit I couldn't see how they were really different.
Now you all know why I use an alias instead of my real name....
02-11-2010 10:41 AM
jvh75021 wrote:Mega Duhs on me!...
Where were you when I thought it was cool that my name was still unregistered? ![]()
Ben
02-11-2010 11:17 AM
jvh75021 wrote:Mega Duhs on me! I kept looking at that and thinking it was 2 different display formats, not 2 different objects, though I admit I couldn't see how they were really different.
Nah, it's nothing to worry about. The more you practise, the more such stories you can tell. E.g. today it took me about 10 minutes to realize that the problem why I can't draw a scale on a desired picture is only because I have forgot to wire the "scale specs" input to the Draw Scale.vi. ![]()
02-11-2010 11:22 AM
In the heat of battle I found myself frustrated because I could not get a control to react when I typed a new value. So I posted thinking I had a bug and Dennis replied something to the effect;
"Advnaced >>> Enabled State >>> Enable
Ben
02-11-2010 11:47 AM
I'm sure you never forgot that one.
Two ways to learn... Through knowledge or through mistakes.
Somehow, karma chose mistakes for me.. Likely due to a lack of patience... And being ADD 😉 😛
I have to learn to relax, but I have no patience for it... 😮
Back to ++sea...
