Number of lines in a file
is there an existing component to determine the number of lines in a .txt
file for example?
TIA,
Bull's
(3,231 Views)
Unfortunately no. You will have to build one yourself. The basic way to approach things is to pass the contents of the file into a while loop containing a match pattern primative. Have a shift register on the loop that carries the location of the last sting found and loop until the search string isn't found anymore. When the loop terminates the number of iterations will be equal to the number of lines.
The one tricky part is defining the search string. If you know what the EOL delmiter is for the program generating the file is--use it. Otherwise try the string [\r\n]+ (with slash codes enabled). This string will match any number of consecutive carriage returns or line feeds. The only problem with this generic solution is that it won't catch empty lines...
If you can't get something going give me a hollar and I'll put something together for you...
Mike
mporter@arielcorp.com
Certified LabVIEW Architect
LabVIEW Champion
(3,231 Views)
Thx for the help
While waiting for an answer, I figured out how to do it myself, andd
surprisingly just the way you said
Greetz
Bull's
"mikeporter" schreef in bericht
news:506500000005000000285E0000-1012609683000@exchange.ni.com...
> the EOL delmiter is
> Mike
(3,231 Views)
Steven,
Under Functions> File I/O menu is a "Read Lines From File.vi".
Wire your file path refnum into it, It will output a line string.
Wire that into a "Spreadsheet String to Array.vi" with a "Carriage Return" constant wired into the delimiter input.
Wire its output array into an "Array size.vi" and you should have your number of lines.
Good Luck with it, Doug
(3,231 Views)
Thx, this one is much shorter than the one I wrote myself...
"Doug (CapeFl)" schreef in bericht
news:5065000000050000002D5E0000-1012609683000@exchange.ni.com...
> Steven,
> number of lines.
(3,231 Views)
