Number of samples for Statistics VI
It looks like the numbers were not saved properly. I have my sampling rate at 10000, number of samples per channel is 1000, and the sample length at 100. So what you're saying is I need to control the number of samples collected (lets say 100) so that if I get 100 samples collected in my loop it will average every sample collected?
What i'm eventually going to be measuring is a voltage from a sensor which has very little fluctuation (it is a laser sensor so it will be fairly constant).
Message 11 of 12
(248 Views)
Yes.  You will have to pay attention to the number of samples and sample rate.
Now you are saying that you have a signal with very little fluctuation.  So where is your problem?  You started out with your problem saying that you had a sine wave that wasn't averaging the way you though it would.
Message 12 of 12
(238 Views)
