Number to Decimal String [Array Coercion]
I've noticed when using the Number To Decimal String Primitive on Arrays there is a Coercion Dot. If there are any Wizards behind the curtain on the forum, Is this anything more than a polymorphism oddity?
How does the NI compiler handle this primitive with Integer Arrays?
________/~~~~~~~~*********~~~~~~~~\________
Certified delinquent LabVIEW developer. Recertifying at next NI Days
(3,470 Views)
Accepted by topic author szewczak
That has been reported ~decades ago and it is probably just a cosmetic problem.
(3,468 Views)
In "google before you post" I found that, and it seemed so old it couldn't possibly be the same issue. lesson learned.
(3,441 Views)
