Numbering Row Headers in Tables on Front Panel
I ran across an example that had a Table on the front panel and the first column was the Row Header (you have the option of making it visible) and it was numbered 0 - 127, as there were 128 data points created using some waveform graphing functions.  How do you get the first column (Row Header - which gets added to the Front Panel Table if you make the Row Header visible?  I don't think that someone sat there and entered 0 - 127 off the Front Panel.
Also, on the graphs, which by default have a black background - how can you change the color of the background?  I can change the trace colors, but have been unsuccessful changing the background color.
(2,758 Views)
Accepted by topic author djpritchard
The row and column headers can be written programmatically using property nodes:
For the graph background you can just use the color tool from the Tools palette. Just select the tool,  right-click on an area that's the background, and select the color you want from the popup window.
Message Edited by smercurio_fc on 12-06-2009 09:40 AM
(2,745 Views)
