Numbers saved as strings in excel using report generation
I am using "Excel easy table.vi" to collect data from LabVIEW to excel. The problem is that the number array I read from LabVIEW, is stored as strings in excel. I want to save those as scientific numbers.
I have tried using "set cell format.vi", but it will not help me.
Can anyone help me?
Paul
(2,678 Views)
Hi Paul,
What did you use for the number format input ? Can you send your VI ?
It works perfectly fine for me :
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
(2,657 Views)
Hi Maxime!
It looks like If the input value is scientific, excel converts it to a string.
Please see the attached example.
Paul
(2,636 Views)
