Numeric Control Disable
Hi, I have a numeric control. I want to disable the option of having the user enter a number and hit enter. I only want them to be able to use the up and down arrows to change the control. Is this possible and how do i implement this? Thanks!
Message 1 of 10
(5,374 Views)
Select a "flat box" from decorations->Flat box, resize/move it to exactly cover the Numeric control user entry field and paint it transparent . Group it the flat box & Numeric control
See attached example.
-Kumar.B
Message 2 of 10
(5,366 Views)
See the following link here
-Kumar.B
Message 3 of 10
(5,362 Views)
Or catch all key events, and disgard them.
Wiebe.
Message 4 of 10
(5,346 Views)
I like Kumar B's advice, but you should save it as a typedef.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
Message 5 of 10
(5,337 Views)
Hai TWGomez,
But when i used ur control in my vi it is accepting input from the keyboard....
Mathan
Message 6 of 10
(5,331 Views)
You actually running the program or just put it on your front panel and clicked on it??? You can type on it if the program isn't running....you can't when it is running...
Message 7 of 10
(5,328 Views)
Wait...I posted the wrong one 😛
EDIT: Actually I didn't post the wrong one...When you save this make sure you save it disk then place the control on the front panel....I added it the block diagram via drag/drop, but came in as a constant (which I converted to a control), and it didn't work right....So save it, then add the control to the front panel via the controls pallete.
Message Edited by TWGomez on 04-22-2008 07:15 AM
Message 8 of 10
(5,327 Views)
That worked....
Mathan
Message 9 of 10
(5,322 Views)
"TWGomez" <x@no.email> wrote in message
news:1208866206469-693657@exchange.ni.com...
Be careful though. Using this method, you can still tab to the control to
give it key focus. You might not want to disable tabbing for the control,
because tabbing is sometimes very convenient.
Wiebe.
Message 10 of 10
(5,286 Views)
