Numeric Indicator displays different shapes given different outputs
So I have a numeric indicator. Numbers are fed into the indicator and I would like the VI to perform so that given a certain number is input, a specific shape will correspond to that number.
For example, if the indicator outputs a 3 then a circle appears on the Front Panel. If it's a 2 then you see a square. And if a 1 then you see a circle.
Something like that. But is there some type of function I can use to somehow link the shapes with the numbers?
(2,840 Views)
try a picture ring. 🙂
(2,837 Views)
