Numeric array position
I would like to know how to insert one number in the four position of a numeric array.
Best regards
Message 1 of 20
(4,977 Views)
Accepted by topic author labview99
Hi 99,
There is a function palette for array functions. One of those functions is named "Insert Into Array"…
You got comments on those Training resource offered in the LabVIEW board before, did you?
Message 2 of 20
(4,957 Views)
It gaves me an error
Message 3 of 20
(4,941 Views)
Hi 99,
and what is the reason of the error? Did you read the context help when hovering the mouse over that broken arrow?
Again: you got comments to take the free Training courses, did you? This is very basic LabVIEW stuff!
Maybe because there is no array where you can insert an element!?
Message 4 of 20
(4,938 Views)
Okey, thank you for your help
Best regards
Message 5 of 20
(4,933 Views)
SO, if there is no array where I can insert an element, How can I do it?
Message 6 of 20
(4,925 Views)
Think about your question for a minute. You're asking how to put an element into an array that does not exist. That would be like trying to pour coffee into a cup that does not exist - you have to get the cup first. Make an array. As GerdW has said you should really take a look at the basic LabVIEW training material. You will spend more time on simple stuff like this than it will take to complete the training materials.
Message 7 of 20
(4,921 Views)
I have already created the array
Message 8 of 20
(4,918 Views)
The problem is that I can´t connect the number to the first channel of the function insert into array
Message 9 of 20
(4,917 Views)
No, the problem is that you're trying to connect a number to an array input of the insert into array. If you want to create an array then there are appropriate functions on the array palette.
Message 10 of 20
(4,911 Views)
