Numeric array with 1's and 0's to text
I need to convert the bits stream into the string and then to a text. My bit stream is in numeric array. I need to combine these elements to convert them to string and get the ASCII code for text. I've attached an image explaining what I'm trying to do. Screenshot (4).png
(2,459 Views)
Hi hammad,
with LabVIEW:
(2,453 Views)
Hey GerdW!
Can you tell me the name of the block after Number to String Array conversion?
(2,450 Views)
Concatenate String…
(2,401 Views)
