Numeric cluster conversion issue
Here's the situation:
Screen Shot 2015-09-29 at 15.01.56.pngScreen Shot 2015-09-29 at 15.01.56.png
The source wire to the left has this description:
Screen Shot 2015-09-29 at 15.08.33.pngScreen Shot 2015-09-29 at 15.08.33.png
It is therefore a perfectly legit cluster of numerics.
Hence, according to the detailed help of the "To Quad Integer" function, the conversion should not break the wire.
However it does.
What gives?
Tested in LV 2015 64 bit
Note: disconnecting from the Typedef doesn't help, neither does Ctrl+Run Arrow.
(3,493 Views)
Accepted by topic author X.
Answer: the unit, stupid!
(3,484 Views)
