Numeric gauge both indicator and control possible%3F
Is it possible to have a Number Gauge that has two Needles but one is an indicator and the other a control?
Needle 1 = desired value (control)
Needle 2 = actual value (indicator)
(2,999 Views)
In order to be able to operate, it needs to be a control.
  • You can use an event structure and reset one of the needles if it gets operated.
  • You can use one control and one indicator with one needle each. Place the control on top of the indicator and make its background transparent to see both.
  • etc.
(2,980 Views)
That's what I figured. Possible recommendation to NI...
(2,966 Views)
