Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Numeric variable in Labview 5.1
Bull's Eye
Member
02-06-2002
09:06 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is it possible to use a variable in an equation, then put another value
in the variable, and then using the variable again in the equation?
tia,
bull's
0
Kudos
Message
1
of 2
(3,126 Views)
Reply
Re: Numeric variable in Labview 5.1
Oleg
Active Participant
02-06-2002
09:32 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you just have to organize your equation into subVI and connect your variables to its input and output nodes. So each time you call this subVI you can pass there new values of input variables.
Good luck.
Oleg Chutko.
0
Kudos
Message
2
of 2
(3,126 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
