NumericArrayResize crash
What's wrong when NumericArrayResize CIN function crashed. The weird thing is that it didn't crash until I recompiled my DLL made in Labview. The code crashes at NumericArrayResize call even if I don't call my labview DLL. I extracted the relevant parts of the code to below.
#include "extcode.h"
typedef struct {
    long dimSize;
    double Value[1];
    } TD3;
typedef TD3 **TD3Hdl;
void NervusFile::Crash(void)
      TD3Hdl dtHdl=NULL;
      long channels = 32;
      dtHdl= (TD3Hdl)(DSNewHandle(sizeof(TD3)));
         NumericArrayResize(0x0A, 1, (UHandle *) &dtHdl, channels);
Tomi Maila
(3,901 Views)
typedef struct {
    long dimSize;
    double Value[1];
    } TD3;
      TD3Hdl dtHdl=NULL;
      long channels = 32;
NumericArrayResize can allocate a new handle when passed in a NULL handle. And it is always a good idea to actually
check your error return values. Last but not least since you are using C++ here your Crash method might be invoked somehow through the constructor of your object. Hard to say without seeing all the code.
MgErr NervusFile::Crash(void)
      TD3Hdl dtHdl=NULL;
      long channels = 32;
      MgErr err =  NumericArrayResize(fD, 1, (UHandle *) &dtHdl, channels);
      /* since the handle is not passed out it would be a good idea to actually deallocate it again.
         Are you sure this method is not somewhere called in a circular reference over and over again,
         which would create an out of mem condition at some point? */
      if (!err)
         err = DSDisposeHandle(
dtHdl);
      return err;
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,874 Views)
rolfk:NumericArrayResize can allocate a new handle when passed in a NULL handle.
I'm not shure you are right, please look here
Is there a bug in arrresize.c and in the documentation?
(3,543 Views)
I'm not sure what you try to show in that other thread. For me it simply lacks any consistent theme and context.
But I'm 100% sure that the NumericArrayResize() function that is exported by the LabVIEW kernel will work properly with this code:
UHandle h = NULL;
MgErr err = NumericArrayResize(uB, 1, &h, size);
and allocate an according handle of size bytes.
(3,515 Views)
