Numerical Indicator Update Rate
Hello all.
I am reading and charting several voltages. I am also using a numerical display of the same data.
I would like the charts to be updated continuously, but the numerical displays only updated say every 250ms.
I cannot find an option for this, I have checked the forum and help pages and could not find anything similar.
Message 1 of 18
(5,961 Views)
Hello KevC,
just put the indicator into a (while) loop containing a "wait for next multiple" with your desired update time. Then connect the indicator with your data source. (Easiest solution could be a local variable to allow proper data flow...).
Message 2 of 18
(5,954 Views)
Hi GerdW
Thanks for the reply.
Will this have the effect of updating everything in the while loop at such a rate, including the charts?
I have 5 numerical displays and 3 charts in total.
Thanks again
Message 3 of 18
(5,951 Views)
Hello KevC,
roughly said: an indicator gets updated when new data is written into. So everything in a loop that gets new data is updated on the frontpanel.
But you asked "how to update a single indicator at a given interval?". So put just the needed indicators into the loop and leave the rest untouched.
Message 4 of 18
(5,941 Views)
Thats fine now, just checking.
Many thanks.
Message 5 of 18
(5,933 Views)
Hello again.
Sorry to ask you to go over this again.
My VI consists of 1 while loop, where the tasks are configured outside, and everything that must be updated contiually is inside.
How do I use another while loop with the wait function to update the numerical indicator?
Best Wishes
Kevin
Message 6 of 18
(5,901 Views)
Hi there,
A quick way to do it would be with local variables. Here's a little example that simulates a signal, graphs it continuously and outputs a numeric value every 500ms. I'd recommend putting some form of timing in the main loop to stop it eating all your CPU though!
Sarah
Applications Engineer | National Instruments | UK & Ireland
Message 7 of 18
(5,862 Views)
Hello Sarah.
I had problems opening the attached file. I am using Labview v7.1.
Message 8 of 18
(5,851 Views)
Sorry, it was in v8, here it is in v7.1.
Sarah
Message 9 of 18
(5,824 Views)
Oh, i see.
Many thanks Sarah, Greatly appreciated.
Best Regards
Kevin
Message 10 of 18
(5,826 Views)
