Nut threading inspection
Hello everyone,
I have a application in which I want to inspect a M6 size hole for threading.
It is a simple 'go/no go' system to check if threading is present or not. No need for the quality of threading, pitch, etc
Is this possible in Labview using a USB camera or something? If yes, can anyone give me some idea?
Thanks. I appreciate your help.
(4,042 Views)
Accepted by topic author rk_t
yes its possible!
Need the following NI Software
Vision Aquisition Module (VAS)
Vision Developement Module
IMAQ dx Module
Learn More About NI VISION
https://decibel.ni.com/content/docs/DOC-46492
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,030 Views)
Thank you very much for your reply.
One more question: what are the other requirements for a vision system? Lighting? etc
(4,028 Views)
There are multiple things you need to consider:
-Camera, Light, Test Object, Test Environment, Software, Part Presentation etc..
Start reading here: http://zone.ni.com/reference/en-XX/help/370281AC-01/TOC1.htm
and this http://zone.ni.com/reference/en-XX/help/370281AC-01/TOC32.htm
Edit: There is separate board for Machine vision specific questions here: https://forums.ni.com/t5/Machine-Vision/bd-p/200
uday
(4,009 Views)
