OCX support under LabView-RT ?
I now that LabView for windows supports OCX(ActiveX) calls, but does LabView-RT support it ? The dll handles TCP communications with some proprietary equipment..otherwise I'd write native support.
Anyone know ?
(3,113 Views)
Taken from the RT User Manual:
The following features do not work on an RT target:
� ActiveX VIs
� .NET VIs
� VIs that use NI-IVI drivers
� Windows Registry Access VIs
� TestStand VIs (ActiveX-based)
� Report Generation Toolkit VIs
� Call Library Nodes that access an operating system API other than
Pharlap
� Graphics and Sound VIs
� Database Connectivity Toolset
� XML DOM Parser and G Web Server for CGI Support
(3,113 Views)
