ODBC after close still open (using multiple connections)
we face follwoing problem using database connectivity toolkit:
We're using two database connections via ODBC, one to a local ACCESS file, another to a SAPDB.
If both connections are opened and the second is closed, this connection keeps still open until the first connection also is closed.
This can be seen in the log file of the ODBC driver (Trace SQL commands).
Any idea?
Thanks, Thomas.
(3,564 Views)
Hello maximint
When you say close, are you referring to destroy/close the reference? Can you provide an screenshot of your code?
Regards
Mart G
(3,528 Views)
attached the code. It's just a DB Tool Close Connection provided with the NI Connectivity Tool Kit.
Thanks, Thomas.
(3,516 Views)
Post your VI. It will be easy to debug (2011 format)
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,512 Views)
attached the code in LV 2011.
BR
Thomas.
(3,506 Views)
PLS provide the same in labview 2009
(3,439 Views)
The attached code should work for 2009.
Arham H
(3,424 Views)
