ODE Solver
Hi Jim,
Thanks for your reply.
The graph image I posted in my original post is the reference benchmark file. I don't know which environment has been used to produce this graph. I just need to produce the same results in LabVIEW using ODE Solver.vi. The HTML file of this graph (which I have downloaded from the benchmark suite at www.sbml.org) is also attached.
Regards
Hasan
Message 11 of 15
(2,408 Views)
Hasan,
It looks like there is a mismatch between the ODE being solved in LabVIEW and the ODE that was solved to produce the graph you show from sbml.org.
I was able to reproduce the graph if I used the following ODE right-hand-sides:
-(k1)*a0+(k2/compartment)*a1^2
2*(k1)*a0 - 2*(k2/compartment)*a1^2
I don't know which ODE is correct given the reactions you are modeling as this is not an area of expertise for me, but I believe the ODE solver in LabVIEW is producing a correct output given the RHS.
I am still puzzled by the issues with your typedef.
-Jim
Message 12 of 15
(2,390 Views)
Hi Jim,
Thanks for your reply and efforts you are putting to solve this problem.
Yes, the equations you have given are producing the same results but the ODEs which I am solving in LabVIEW is similar to those being solved in other tools to produce the graph similar to the one I attached in my original post. I checked the ODEs in other tools and they generate the correct results, however, I don't understand why is it not producing the same results in LabVIEW.
The simulation parameters cluster is not a TypeDef in my program.
Regards
Hasan
Message 13 of 15
(2,369 Views)
Accepted by topic author Hasan-Baig
Hasan,
I believe there is a mismatch in the units of the ODE. According to the SBML website this problem is described as:
The model contains one compartment called "compartment". There are two species named S1 and S2 and two parameters named k1 and k2. The model contains two reactions defined as:
Reaction Rate
S1 → 2 S2 k1 · S1 · compartment
2 S2 → S1 k2 · S2 · S2 · compartment
The initial conditions are as follows:
  Value Units
Initial amount of S1 1.5 × 10−4 mole
Initial amount of S2 0 × mole
Value of parameter k1 0.35 second-1
Value of parameter k2 180 litre mole-1 second-1
Volume of compartment "compartment" 0.3 litre
The species values are given as amounts of substance to make it easier to use the model in a discrete stochastic simulator, but (as per usual SBML principles) their symbols represent their values in concentration units where they appear in expressions.
I think you are using a0 to represent s1, and a1 to represent s2 in your ODE RHS equations, but to be consistent lets keep s1 and s2.
Your RHS side equations are therefore:
ds1/dt = -(compartment*k1*s1)+(compartment*k2*s2^2)
ds2/dt = -2*(compartment*k2*s2^2)+2*(compartment*k1*s1)
Your initial values for the s1 and s2 are 0.00015 and 0, just as the problem description states. This implies that the units of S1 and s2 are moles.
The graph of s1,s2 VS time from the SBML website also supports this, as the s1 trace begins at 0.00015 and the s2 trace begins at 0.
Now lets look at the units that derive from the first RHS equation:
units of compartment = litre
units of k1=1/second
units of s1=mole
ds1/dt is the rate of change of s1 over time, so this should be mole/second.
So the first term (compartment*k1*s1) has units of (litre)(1/second)(mole) or (litre*mole/second). This does not match the units of ds1/dt.
The SBML description has a note at the bottom that seems to describe the issue
The symbol s1 in the reaction rate equation you used to derive the ODE has units of concentration, which I think should be Molarity (mole/litre). However, the variable s1 and s2 in the ODE have units of mole, and so should be be scaled by volume. s1->s1/compartment, s2->s2/compartment
This makes the RHS equations:
ds1/dt = -(compartment*k1*(s1/compartment))+(compartment*k2*(s2/compartment)^2)
ds2/dt = -2*(compartment*k2*(s2/compartment)^2)+2*(compartment*k1*(s1/compartment))
simplifying we get:
ds1/dt = -(k1)*s1+(k2/compartment)*s2^2
ds2/dt = 2*(k1)*s1 - 2*(k2/compartment)*s2^2
Which are the equations I found empirically yesterday.
Could this be the problem?
-Jim
Message 14 of 15
(2,335 Views)
Hi Jim,
Thanks a lot for your help and detailed guidance. I understand it completely and you got it right.
Thanks again. You deserved kudos 😉
Regards
Hasan
Message 15 of 15
(2,304 Views)
